97 2wd f150 Help
It depends on how high you want to go. Daystar spacers are about $100 and will give you 2 inches of lift, a 3 inch body lift is about $150 and a set of 3.5 inche lift spindles will cost a couple hundred bucks (I think). And you can always combine all 3. If you do the work yourself it will still be less than a full suspension lift.
