Sponsored by: CARiD
1" Lift Front Coil Spacer
Old Apr 9, 2007 | 04:51 PM
GerRod's Avatar
Is there a 1" lift front coil spacer for a 2006 5.4L 2WD? If so, where can I get it?
Old Apr 9, 2007 | 05:39 PM
bud8817's Avatar
daystar and procomp make a 2.5 in spacer that contains a 1" coil spacer which goes inside the coil itself and a 1.5" coilover spacer which goes on top of the entire coil over if you only use the coil spacer you will have 1 to 1.5 inches of lift and that my freind is the only way trust me. thats what i did to get rid of the rubbing in the front of my truck.
Old Apr 9, 2007 | 05:51 PM
GerRod's Avatar
So they make a 2.5" spacer that consist of a 1" spacer and 1.5" spacer...so you can use either and don't have to use both???
I see you're using the 1.5" in your sig...do you have the 1" available for sale???
Old Apr 9, 2007 | 06:10 PM
wandell's Avatar
I believe that most companies that make leveling kits make 1 inch versions.
Old Apr 9, 2007 | 06:24 PM
hazelbalz's Avatar
I will have a 1.5" available for sale after tomorrow. Im taking it off my truck to put a bigger one on. it is the one made by revtek. I will sell it for a good price if you are interested.
Old Apr 9, 2007 | 06:28 PM
hazelbalz's Avatar
I stand corrected its the 2". Let me know if you are interested.
Old Apr 9, 2007 | 06:34 PM
GerRod's Avatar
Wandell...thanks...I'll make some phone calls...
Thanks, but 2" is too much...I need 1"...
Old Apr 9, 2007 | 06:55 PM
hazelbalz's Avatar
not a problem, hope that you can find one
