Sponsored by: CARiD
major shock problem, almost died!
Old Apr 7, 2007 | 11:53 PM
MmmBuckles's Avatar
Exclamation major shock problem, almost died!
alright. so i was on my way home from work about 30 minutes ago. i was driving through a light that is on a slightly curved road, and its been raining. i didnt realize that there was a little bump right on the other side of the intersection. so i going about 35 on a wet curve, i hit the bump and got some air. as soon as i hit the ground i started sliding and i heard a loud pop noise. i did a 360 and kept sliding. some how i managed to stop about a foot away from a muddy ditch. i pulled of to check out the damage, and it looks like the left side of my truck is sagging in the rear. could i have busted a shock? everything else looks fine. im pretty sure they are the same shocks that came with the truck,btw is a '98. so do yall thinks its time to change them? and if so what kind should i get? i dont want to spend a fortune, but i want something better than stock.
Old Apr 8, 2007 | 09:09 AM
wandell's Avatar
Your shocks don't support the vehciles weight so that is not the problem. Take a look at your leaf springs, shackles, hangers, etc for something broken.
Old Apr 8, 2007 | 11:29 PM
Veteran: Army
sounds like you may have broken a bolt on your rear suspension OR you may have bent something
Old Apr 10, 2007 | 09:26 PM
skirk55's Avatar
The front shocks on my 2005 F350 went dry. The truck just bottomed out and bounced. My front shocks went dry not the rear. You could not have a coffee in the truck! I put Pro Comp MX6 shocks on the truck now and what a difference.
Old Apr 10, 2007 | 09:57 PM
APT's Avatar
APT
First, Wandell is right that shocks don't hold the weight of a vehicle so I'd look more closely at the springs and connecting hardware.
Second, your truck's shocks were bad at 10k miles, so you will notice a significant improvement to ride and control with new ones. Rancho has a promotion right now for buy three get one free. First, get the springs fixed.
Old Apr 10, 2007 | 10:34 PM
MmmBuckles's Avatar
ya. i found out what it was, the u-bolt holding my leafs on snapped. i have no idea how that happened but it did. i got a new one and its fine now. but i think my shocks could still use some replacing
Old Apr 11, 2007 | 04:34 PM
huntrboy475's Avatar
Good to hear that your ok though
Old Apr 11, 2007 | 05:18 PM
skirk55's Avatar
Thank God he saved the Ford!
