Sponsored by: CARiD
Spindle Lift Question
Old Apr 6, 2007 | 07:03 PM
mustang3475's Avatar
Question Spindle Lift Question
Hey guys I just installed the 3.5" Doetsch spindles, and the quality of the spindle was very good. The only thing that I had to modify, was the lower control arm. The spindle touched the lower control arm a bit, and that was it, and I also couldn't install the splash shield. Anyway, I know the tires are suppost to stick out a little, but what about the back. I have seen other trucks and both the front and rear tires stick out the same. I have 2" blocks in the back. Thanks, I also have 275/65/18 on it, and the tires look a little small, what size should I go with? Thanks again! O its a 2wd
Old Apr 6, 2007 | 07:15 PM
mlsman23's Avatar
The rear tires will stay the same, just the front will be pushed out. And the reason some trucks tires stick out in both the front and rear is because of the backspacing on the wheels I think.
Old Apr 6, 2007 | 10:12 PM
wandell's Avatar
Some people have used wheel spacer to widen the rear track width to match the front.
