06 Screw lift
Originally Posted by ThumperMX113
Remember a 6" lift for your 2WD will sit 2" lower than a 4WD model equipped with the same lift.
silverf1504x2
? Will a 5" block sit the same as your 2"& 3"leaf combo. Is it a true 5". Reason i ask , been thinking about putting my 2.5"as on my truck.[ 6"lift with 5" blks]. I see you have a 2" spacer. Does your truck sit level? Any info helps, thanx
by the way nice truck
Mine sits pretty level. The back may be slightly higher but not much. I went with the 2' spacer just to be safe from bad cv angles. I know it's only 1/2 inch difference from the 2.5 but it made me feel a little better. On the rear i have the 2' Fabtech block with the 3' add a leaf which should be the same as the 5' block i would think.
