Sponsored by: CARiD
AS or TopGunzCustoms
Old Mar 30, 2007 | 12:06 PM
ameration's Avatar
What is the difference between the AS 2.5" leveling kit and the TopGunCustomz 2.5" kit?
Installed the TopGunCustomz kit on a friend's 2005 FX4 almost 20k ago and no problems.
Also, many of you are adding the 1.5" AAL after adding the 2.5" leveling kit. Doesn't that make the rear too high again?
Old Mar 30, 2007 | 02:32 PM
roloplex's Avatar
There is no difference....they are the exact same thing
Old Mar 30, 2007 | 02:38 PM
ameration's Avatar
I did notice that the AS kit listing has this in the description:
This is our re-designed offset version. No other kit manufacturers offer this. The 1/4" offset keeps the upper control arm from rubbing the coil spring during full upward deflection.
Go to the Ford owners forum F-150online.com to find out more . **WITHOUT THIS OFFSET YOU RISK DAMAGING YOUR UPPER CONTROL ARMS AND COIL SPRINGS. THE OFFSET DOES NOT IN ANY WAY EFFECT THE HANDLING CHARACTERISTICS OR FACTORY RIDE QUALITY**
True???
