Sponsored by: CARiD
Alignment required after shock replacement?
Old Mar 29, 2007 | 06:59 PM
Jesse H's Avatar
Just as the title indicates. Also, I searched and it sounds like although they're coil springs up front, I won't need a spring compressor to drop the shocks?
Thanks all.
Old Mar 29, 2007 | 07:09 PM
deapee's Avatar
The shocks you should be able to just pop right out without doing much at all. Technically you could do it without removing a tire if there was room. As far as an alignment, it's not a bad idea to have one done...but replacing shocks doesn't place a need on an alignment like replacing a tie-rod would, for example.
Old Mar 29, 2007 | 07:38 PM
hmustang's Avatar
It might be a good idea to have it done just in case it was out before you replaced the shocks but you can get by without having it done.
Old Mar 29, 2007 | 09:28 PM
Jesse H's Avatar
Cool thanks!
