Sponsored by: CARiD
2in coil spacer?/bigger spring
Old Mar 18, 2007 | 08:17 PM
superWiff's Avatar
hello everyone im wanting to put 33 all the way around on my truck cause we all know bigger is better .but they wont fit unless i lift it and my paretns wont let me put a 4 or 6'' on there beacuse its not 4x4 so they agreed to let me put the 2in coil spacers on there.will they work and if i put a biger coil spring on there as well will it be enough to put 33s on there also will they rub or only rub when when turning the wheel all the way..
the truck is a 96 f150 2wd thanks all
Old Mar 18, 2007 | 08:22 PM
wandell's Avatar
I'm not sure about your truck but odds are you cannot combine lift coils and spacers and get the alignment anywhere near specs. I'd suggest considering the coilspring spacers and a 3 inch Performance Accessories body lift.
Old Mar 18, 2007 | 08:30 PM
superWiff's Avatar
ok i didnt know that but if i did just the coil spacers would the tires fit
