Sponsored by: CARiD
Total Truck Height?????
Old Mar 18, 2007 | 12:02 PM
Backnblackfx4's Avatar
Does any one know what the roof height of my truck would be with the following... 2.5" Level kit and 35" tires. The Truck is an 06 fx4 with 18" stock rims. Just wanna make sure she will still fit in the garage. Thanks
Old Mar 18, 2007 | 01:37 PM
xXDroneXx's Avatar
what is the height of your garage and maybe someone can give you an answer off of that
Old Mar 18, 2007 | 01:45 PM
hmfic's Avatar
If you at least have a standard sized garage door, you will fit. I had the same setup with 33's and still had a few inches to go.. The antenna will annoy the hell out of you though.
Old Mar 18, 2007 | 05:32 PM
Garage Height is about 80". It seems as if it will fit but just wanted to make sure,...thanks for the replys
Old Mar 19, 2007 | 10:39 PM
xXDroneXx's Avatar
you will fit no problem. I have a 6" and mine would be close.
Old Mar 21, 2007 | 05:36 PM
WOW... If i knew for sure on still fitting in the garage with a 6" and 35's i would go that route for sure! Thanks again!
Old Mar 21, 2007 | 05:44 PM
BalogUK's Avatar
my truck is 6'8.5" with a 2.5" autospring and 35's
