Sponsored by: CARiD
3inch body lift question?
Old Mar 18, 2007 | 12:22 AM
bigbamafan1988's Avatar
I drive an 04 F150 supercrew, and i am new to lifting trucks and dont really know much about it, i want something to make my truck bigger, but its a two wheel drive so i dont want alot, so i am leaning towards a 3 inch body lift, my question is how big a tire can i run, and about how much will it cost, and what is the best brand?
Thanks for the help.
Old Mar 18, 2007 | 05:55 AM
Fordwitflows's Avatar
with a 3" body lift you can run a 33" tire. Some run 35's with trimming of the lower valance. A body lift cost right around $200-$300. The best brand by far and most popular is performance accessories.
Old Mar 18, 2007 | 06:27 AM
nooq's Avatar
i would run a 33" tire with aftermarket wheels. I would MAYBE try a 35" tire with stock wheels. But a body lift is defineatly a option, i have had no problems with mine and i have mixed it with a suspension setup (supposedly the worst scenario). good luck with the install. BTW, the body mount bushings are press fitted, get a press to get them out. Thats all i gotta say about body lifts. Good luck!
Old Mar 18, 2007 | 07:44 AM
xXDroneXx's Avatar
since you have a 2wd, you will only be able to go with 33"s.
Old Mar 18, 2007 | 09:56 AM
wandell's Avatar
I agree. You may be able to fit 35's if you also add a leveling kit. One thing to consider is the cost of installation. If you can do the installation yourself, a body lift is a great value. The 04-07's are supposed to be a real PITA to install body lifts on. If you have to pay someone to install it, you may wind up with almost as much money invested at you would with a 6 inch Pro Comp lift. Just be sure to compare total prices.
Old Mar 18, 2007 | 10:50 AM
Streetstar's Avatar
I agree -- try a spacer kit from Autospring or Daystar first for a mild lift.
But don't be shy about shooting the moon with a suspension lift because its a 2wd, if you have the finances. Some of the trickest trucks i have seen are lifted 2wd's.
On the west Coast - 4wd's are rare and many people lift 2wds' ---
The reason is because of the popularity of desert type trucks -- 4wd's are perceived as too heavy for that type of use (although the point is moot for new, stock trucks, because even a 2wd weighs 5k)
So IMO, having a serious lift on a 2wd gets you style points. However, i myself just went with a Daystar levelling kit and 33's on the stock wheels because it looks good, but is not so high that i need to add sidesteps or anything, because i use my truck frequently for work, and getting stuff in and out of a lifted p/u bed can be a pain
Old Mar 18, 2007 | 11:02 AM
epiphone_eti's Avatar
I want to get a 3" Body Lift for my truck (1983 F-150 4X4). Is this an installation that you need a lift for? If not, can someone who has never done this do it? How much is installation on a 3" Body Lift on one of these older trucks?Thanx.
Old Mar 18, 2007 | 01:22 PM
Streetstar's Avatar
You need a couple of good floor jacks, some blocks of wood and a whole weekend devoted to it if its your first time to do one ----
The process is not hard in theory, but it is time consuming-- thats why body lifts are almost the exclusive domain of the home mechanic --- if you had to pay a 4 wheel or suspension shop to point it on, it would almost be more cost effective to pay a couple hundred more bucks and do a mild suspension lift
Old Mar 18, 2007 | 02:23 PM
If it is a lift made for my truck would there need to be any cutting? Are any cables or the 4X4 shifter going to need to be extended with a 3" body lift? Also I want to get some 33" X 12.50" tires if I get the lift. Would the 12.50" wide tires fit on my 8" wide wheels without any problems?
Old Mar 18, 2007 | 03:14 PM
wandell's Avatar
It depends on the vehicle. Some trucks have to have an extension welded onto the tranny or transfer case shift levers. If you get a Performance Accessories kit, everything will be addressed by the kit.
Old Mar 18, 2007 | 08:05 PM
about how much would 33's and rims cost?
Old Mar 18, 2007 | 08:29 PM
wandell's Avatar
Honestly as much as you want to spend. Pretty cheap if you go with a set of 15 inch painted steel wheels and off brand tires all the way up to a couple of thousand if you go with a set of 20 inch forged aluminum wheels and a name brand tire. Look at 4Wheel Parts website as a good starting point.
Old Mar 18, 2007 | 10:46 PM
liquid 1's Avatar
I know a guy with a 97 4x2 running 37 mudders no problem, with a spacer kit for his coils and rear block and a 3" body lift looks cool..
wadell, Im new here so I could,nt send a private message, Im installing a 3" body lift this week and I have the K&N FIPK kit and did,nt know if it will still work when I lifted the body from the engine, anyone have advise, I like the filter it has the heat sheild..57 series..
Old Mar 19, 2007 | 12:52 AM
liquid 1's Avatar
I see you have the 77 series K&N filter, was there any problems makeing it work with the 3" body lift, truck looks awesome, Im adding a 3" body to my 2" level kit to run the goodyear AT Extremes 315/70R/17..with the DC1 17x9 rims this week, I have the 57 series with the same heat sheild FIPK kit..
Old Mar 22, 2007 | 09:31 PM
I talked to a huy who is installing a 3" body lift, and it looks like it is going to be realy hard to install. Will I need to extend anything. Also, why does the product say you will need two people.
