Sponsored by: CARiD
lift question?
Old Mar 17, 2007 | 11:14 PM
tylerN's Avatar
lift question?
how much is the average price to get wheels and tires and lif and alignment if i install it myself? also with a 6'' fabtech lift will i have to get really wide tires or can i not go as wide?
Old Mar 18, 2007 | 12:04 AM
jiggle's Avatar
You need to be a little more specific. What kind/size tires and wheels do you want? Is your truck 2 or 4wd? An allignment is anywhere from $60-$110. Nobody says you have to get new tires period. Just because you get a lift doesn't mean you have to go with a wider set of tires. It is much safer to go wider as you go taller, but you do not <i>have</i> to. The way I look at it, if you are already getting new rims, just get wider ones and run a wider tire. There's really no reason not to.
Old Mar 18, 2007 | 12:07 AM
wxscpo's Avatar
Not all lifts, tires and wheels are the same. The final price really depends on the setup you decide to go with. I would easily plan for somewhere around $5k though for total cost though. You can save anywhere from $500 - $800 by doing the install yourself though.
As for tires it's all really a matter of preference. I am going with 12.50" tires when I get my lift installed, but I only have a 2WD and I want to ensure no rubbing issues.
