Sponsored by: CARiD
gears!!!! how hard is it???
Old Mar 17, 2007 | 01:21 PM
bud8817's Avatar
i have heard that you have to take it some were and have them put in and i have heard its a piece of cake to install gears... so can i do it myself or not??? im planning on replacing my 3.73's with 4.56 i have even thought about 4.88's, i have 36" baja claws. any opinions on the size gears i should get...
Old Mar 17, 2007 | 01:31 PM
beckerjs's Avatar
no, you cann't do it yourself, not if you want it to last
Old Mar 17, 2007 | 02:04 PM
ian51279's Avatar
You can do it yourself. It's a pain in the butt though. They have to be setup perfect or they will burn up quick.
Old Mar 17, 2007 | 03:26 PM
wandell's Avatar
Exactly. THe installation is not that hard. It's setting them up correctly that is the hard part. If they are not set up correctly they will howl and make loud noises or burn up shortly. Honestly, the fact that you have to ask whether or not you can do it yourself says that you can't.
Old Mar 17, 2007 | 04:25 PM
ThumperMX113's Avatar
It's not worth spending $700 for the parts only to mess it up and have to spend it again. . but, get 4.88s!
This says it all right here.
Old Mar 18, 2007 | 03:17 PM
kalebarellano's Avatar
If you never try then you will never know how.
I have 4.56's (Also thinking about Detroit True Tracs) and I dont know if I am going to try them myself. I have talked to some people that say its real intimidating, until you actually get in there.
I think it is hard but with the right tools and the ability to call a knowledgeable person, it can be done. I may see if I can get someone to help me (and make sure I dont mess anything up).
From my experience things like this are usually easier than people make them out to be.
Old Mar 18, 2007 | 03:43 PM
I've seen too many ruined gear sets from improper installation. . I'd find someone who knows how to do gears and that is willing to lend a hand. The hardest part is going to be getting the depth correct, which does take special tools by the way.
Old Mar 18, 2007 | 05:19 PM
Ya, I would like to do my own. It may be a pain but at least I will have learned something. I can definitely borrow the tools and I can probably get someone to help me. If you know someone that has done gears before ask them to help you. Or if you are mechanically inclined I would say go for it. Also I dont think its $700, like someone mentioned. I think it is like $350-$450 for front and rear (w/ master install kits) Yukon, Genuine, ect. gears.
Old Mar 18, 2007 | 05:47 PM
I'm mechanically inclinded and I wouldn't do a set of gears without a pro standing over my shoulder. . If you can truely find me a set of Precision gears for $350-450, I'll be very thankful. The best price I found was $700 with master install kits and fluids.
Heres a good thing about getting them installed, if you let 4 Wheel Parts do the install, they have a lifetime warranty & some shops around here match that so I'm sure they will do the same in the surrounding areas of any 4 Wheel Parts dealers.
Old Mar 18, 2007 | 07:02 PM
bud8817's Avatar
how much should i expect to have to pay for gears front and back with install??
Old Mar 18, 2007 | 09:38 PM
$350-$450 doesn't include fluid, but other than that I thought that was just the normal price for a set of gears.
Old Mar 18, 2007 | 10:31 PM
liquid 1's Avatar
My local 4wheel parts in charlotte, nc wants $1600 for front and back re gearing..Thats parts and labor, Ive just installed 315/70/17 34.4 good year AT extremes with stock 3.55 gear 2001 F150 lariat, to get close to stock is 3.86, and 4.10 is the closest, national gear has the motive gearsets for $167.00 with instalation kits per Diff, If I could get ti done for $400 parts and all for truck, Ide sign up tommorow.. I wish..But I do agree its got to be done right, lots of work to just have it go bad, any place thats reasonable and with a warranty is good..
Old Mar 18, 2007 | 10:45 PM
. . like I said before, please find me a link to where I can purchase Precision gears for a 9.75 and a 8.8 reverse cut differentials.
But anyways, I was going to pay 4WP $1500 for parts, installation, lifetime warranty for a set of Precision 4.88s.
Old Mar 18, 2007 | 10:57 PM
liquid 1's Avatar
Thumper just wanted to say youve got yourself one sweeet truck..WOW, so what did you wind up doing..to pull the 37" monsters..
Old Mar 19, 2007 | 12:10 AM
bud8817's Avatar
thanks for everyones replies. im planning on getting gears begining of june, right before i have to start towing my boat around alot. anyone know what the rpm difference between 4.56's and 4.88's would be like at 70mph???
