Big 'ol nuts and bolts
Hey fellas
Anyone who has done a spacer kit on a later model install remember what size the nut and bolt heads are that fasten the strut to the lower control arm?
This is on an '05 2wd -- they are pretty large and i am going to have to pay a visit to Sears to expand my tool collection
Thanks in advance
Thanks in advance
It's actually a 30mm axle nut socket. I borrowed one from autozone. All you have to do is leave a $15 deposit and you get it back when you return the tool. There's no need in buying it since this is the only time you will probably ever need it.
I bought one of these at autozone for 8bucks. I figured I would just buy it instead of rent it. Never know when I might want to do something else with it.
Never met a tool I didn't "need" anyway. I went with the SAE socket (difference is .0075") because the SkyJacker instructions called it that way. The advantage of the 3/4" drive socket was it ended up deep enough to not need a deep socket. I have a buddy with a 3/4 drive rachet... and the extra handle length is nice when you go to tighten and loosen (341 ft lbs!!!).
