Help high velocity vibration after 8" rize install
First thing I would do is go all over the lift again and double check that everything is secure and tight bolt/nut wise. What may seem like it's tight/snug to you may in fact not be? I would have to think that this is the issue. If not, at least you have piece of mind that the lift is secure.
Could very well be like Thumper said a drive shaft issue. If you haven't messed with the driveshaft then you need to take out the front driveshaft, have the master spline cut out and rotate the end so both ends are the same way (may not have to do the rotate on 06), lengthen to 37.5" and have the driveshaft balanced. 8" lift isn't tall enough to get crazy with the driveshaft just some mods and it'll be ok. We had a Mark LT we lifted 14" and had to build a dual velocity driveshaft for it but you're not tall enough for anything extreme like that. Here's a pic of the Mark LT we did.
Plus, I didn't feel right having the driveshaft stick 2" out of the transfer case. .
