CRAP!! 06 suspension problems
So three weeks ago i had a front spacer kit with realign and front replacement put on my 06 screw kind ranch 4x4. a week later i noticed something leaking in the front driver side tire/break/suspension area. Took it in and they said it was a bad strut....fixed under warranty. Saw last night that the other side is doing the same thing.
The guy at the oil change place(I know him personally) thought it was a seal in the axle the first time....anybody had this happen...at 25k miles?
I have seen spacer lifts cause boots to tear and the grease gets all over everything. However, you must also consider that your shocks are over extended which could bust a seal inside the shock causing it to leak.
