Sponsored by: CARiD
AS 1.5 rear leveling block
Old Feb 21, 2007 | 05:08 PM
mx57's Avatar
Has anyone ever used this? I was thinking about adding a 1.5 aal, then i saw this on ebay. Its a little cheaper than the aal, so i was wondering. Thanks alot!
http://cgi.ebay.com/ebaymotors/2004-...spagenameZWDVW
Old Feb 21, 2007 | 05:24 PM
freddytran's Avatar
Looks like Autospring is doing lift blocks now. They look pretty much the same as the 4x4 blocks. I did the AS 2" in front and the 4x4 blocks in th rear. I think I bought my blocks with u-bolts for $50 from a member here.
Old Feb 21, 2007 | 09:22 PM
NASTY-FX4's Avatar
I just installed some last weekend.Very nice product!!!!!!!!!!!!
Old Feb 21, 2007 | 09:26 PM
hmfic's Avatar
Did you just stacked it on top of your factory one then?
Old Feb 22, 2007 | 12:13 PM
wandell's Avatar
That is way too much for a lift block!
Old Feb 22, 2007 | 05:52 PM
NASTY-FX4's Avatar
The new block goes in between the factory block and leafspring.The Fords have double pin blocks.The AS blocks are solid steel with hard steel pins,I bought just the blocks for around $60.I got U-bolts from the lift shop for $25.I went with 1" block,they look awsome on the truck.
Old Feb 24, 2007 | 11:23 PM
05F150FX4's Avatar
are these the same type of blocks they use for a body lift? or are they different blocks? sorry for my stupidity but??? could you still add a body lift with these blocks to add add'nl height???
Old Feb 25, 2007 | 12:51 AM
NASTY-FX4's Avatar
No,They are not the same as body lift.A body lift blocks go between the frame and body.
Old Feb 25, 2007 | 01:16 AM
05F150FX4's Avatar
ok thats what i thought just wanted to make sure!!! thanks
