Sponsored by: CARiD
Help Build My Lift Please
Old Feb 15, 2007 | 10:40 AM
4fit?'s Avatar
I posted up a while back about wanting to raise my truck and got a few responses. Now I am finally buckling down and doing it and I need/want your help. This is for a 99 2wd supercab F150 5.4. What I really want is to raise the front 2" and the rear 1". This should give me a relatively level stance, correct? And I wouldn't need to change shocks, A arms, etc with this small of a lift, right? Only problem is, I can't locate a 2" spacer to use in the front. All of the ones I have found are 1.5" or 2.5" and the 2.5" says that it requires aftermarket A arms. That would put me WAY out of budget. I'm looking at doing this on the cheap, as it is my daily driver and I dump most of my money into my family, house, and Mustang. That's why I was wanting to do with the spring spacers and blocks.
So, what advise/comments/suggestions do you have for me? Any and all replies are immensely appreciated! Thanks in advance!!
Old Feb 15, 2007 | 12:57 PM
wandell's Avatar
I believe the Daystar spacers will give you 2 inches of lift, but they are actually 1.5 inches thick. THat is probably the confusion. You won't need new shocks or anything else if you don't go over 2 inches of lift. Some trucks need camber bolts to get the alignment within specs, but some don't.
Old Feb 15, 2007 | 01:06 PM
1BDf-150's Avatar
You can get a SKG alum 1.5" spacer for $40 call 858-748-3504 ask for alex
I have a alignment kit for sale for $30 my email mikewendt@yahoo.com
and you can get a add a leaf or a small block on ebay for cheap
Old Feb 15, 2007 | 01:11 PM
4fit?'s Avatar
Thanks. I have found a 2" spacer made by TrailMaster. Do you think I'd be better off going with the DayStar? Do you have a link to their site? I can't locate it for some reason. Where would I get a camber bolt and where is it installed? Should I just leave the rear alone, or would a 1" block or 1/2" shackle help? Thanks!!!
Old Feb 15, 2007 | 01:13 PM
4fit?'s Avatar
Is the aluminum supposed to be beater than the urethane ones? Is the alignment kit the camber bolts? Thanks!
Old Feb 15, 2007 | 01:25 PM
1BDf-150's Avatar
Yes I its the camber bolts
Yes I like the alum. ones better because you never lose your lift, I have heard from a few people the urethane ones wear out and you lose half of the hieght
Old Feb 15, 2007 | 01:51 PM
4fit?'s Avatar
Gotcha. Seems like the aluminums would crack due to weight though. That's what I've always heard about the rear blocks anyway. Do you think 1.5" would level the truck out enough to look decent? I'm new to all this lift stuff.
Old Feb 15, 2007 | 01:58 PM
1BDf-150's Avatar
Yes, also the alum spacer sits under the coil instead of on top, Im running it with my lift and have had no issues
Old Feb 15, 2007 | 02:57 PM
4fit?'s Avatar
Alright Mike. I believe you've got me convinced that the SGK one is the one to go with. What all comes in the kit? Would shock bushing spacers be needed? Most of the urethane kits I've seen have one included. Also, I may pick up that alignment kit from you. Where exactly are those camber bolts installed?
Thanks for all the help!
Old Feb 15, 2007 | 04:03 PM
1BDf-150's Avatar
All it is, is the spacer, no other parts are needed
and the camber/caster kit, replaces the bolts and washers in the upper control arm, very easy
Old Feb 15, 2007 | 04:25 PM
4fit?'s Avatar
Thanks for the info! I will probably call SKG tomorrow to order the spacers. Do you think I will need the camber bolts since I am just going with a 1.5" spacer on a 2WD truck? I don't mind spending the money at all if I need them.
Dumb question: 2WDs don't have torsion bars up front, right? Everything I've read is all about 4WDs.
Old Feb 15, 2007 | 08:01 PM
wandell's Avatar
RIght.
Old Feb 15, 2007 | 09:02 PM
1BDf-150's Avatar
correct, and yes you need the aligment kit to get it aligned right, or it will F up your tires
Old Feb 15, 2007 | 09:31 PM
mxr181's Avatar
i have an 02' 2wd supercab, i have already had the daystar coil spacer and it was JUNK, it made the front suspension sqeak and rattle like you would not believe, i finally found the skg aluminum spacers about a month ago. i ordered them, skg was great had them to me in 3 days i think. anyway the skg spacers are MUCH better because they sit below the spring. my daystar spacers were in for just over a year and they caused my shock covers to bend, and they were making my spring come more and more out of the pocket and bow out, with the skg the spring is correct again and there is no noise, and i gained about .5-.75" of ride hieght. so definetly give alex at skg a call and get their spacers
Old Feb 15, 2007 | 09:32 PM
mxr181's Avatar
o and i did not have to mess with the alignment on either setup, my truck drives perfect and the tires are also showing totally even wear.
