Sponsored by: CARiD
fabtech 4" aal
Old Feb 6, 2007 | 04:59 PM
kAkA_r0Ach's Avatar
fabtech 4" aal
by installing this kit will everything (alignment/pitch/angles etc) be ok? i already have a fabtech 6" lift on and the rear sags around 1.5". wanna get the back end up like it was before the lift (oem stance). i do NOT like the pre runner look.
also found an aal from skyjacker but it says the rear end will only be raised around 2-2.5" with my tool box fully loaded along with equiptment and materials in my bed i think the rear would still sag a bit and not even be level
i think the rear end sagging is getting to me more than my qute stock tires with the lift kit.
Old Feb 6, 2007 | 06:52 PM
kAkA_r0Ach's Avatar
sorry for the mix up, just checked out the sites again, i had it backwards
the skyjacker will raise the rear 4" "if im reading it right!!?? =\
again sorry for the mix up......http://www.4wheelparts.com/PDT48603.aspx
Old Feb 7, 2007 | 07:33 PM
ISNMU's Avatar
BDS has a 5 in leaf pack.. i think sjyjacker makes a 6"....... I am unsure of AAL's.... If you haul any amount of weight, I would put a leaf pack in that will handle it and ditch the factory 2 leaf set....
