Sponsored by: CARiD
Drop Shackles
Old Feb 2, 2007 | 12:19 PM
SlammaJamma's Avatar
Drop Shackles
Im thinkin about getting some drop shackles for my '99 4x2 to make it sit more level. My only concern is bottoming out at times. I haul stuff from time to time. Will these shackles limit my abilities by a lot? Will I still be able to put a 4 wheeler in the back without slamming the axle against the bump stops constantly? I know the shackles are only 2" of a drop, but I just wanna make sure before I make the investment. Thanks.
Old Feb 2, 2007 | 12:24 PM
Bryndon's Avatar
They won't change how much the suspension compresses, so, measure the distance to the bumpstops, load her up, and measure again. If the distance is less than 3" you will probably have issues when you hit a bump.
Old Feb 2, 2007 | 04:32 PM
Sounds like a plan, thanks.
Also, can anyone recommend some good quality ones? I was looking at some on ebay that seemed good but the bushings weren't greasable. Is that a good thing or a bad thing?
Old Feb 2, 2007 | 07:56 PM
I'd recommend the Ground Force shackles -- they're one of the only manufacturers who include pinion shims with the kit. Search the forums and you'll find plenty of guys who had vibration problems after installing drop shackles without the shims......
Old Feb 2, 2007 | 08:23 PM
GF shackles here. No probs.
Old Feb 3, 2007 | 03:24 AM
Ground Force with shims here. No problems and looks much better.
Old Feb 4, 2007 | 02:38 AM
Cool cool, does Jegs carry them or is there a better souce?
Old Feb 4, 2007 | 08:47 AM
Here's a Ground force link.
http://www.groundforce.com/vehicle.a...ord&make=F-150
Old Feb 4, 2007 | 10:19 AM
Thanks amigo
Old Feb 4, 2007 | 12:42 PM
jhitti's Avatar
i got belltech 2" shackles and had a truck load of bananas w/ no problems. every weekend i pull a 17' bass tracker or a dirt bike and alteast 2 4-wheelers never had any problems
