Sponsored by: CARiD
Thoughts on body lift
Old Jan 31, 2007 | 02:07 PM
jeffmc's Avatar
I just installed a Warn 9,000 lb winch and Trans4mer grille guard. The winch alone weighs 90 lbs and the grille guard makes the total added weight 120+. The front end came down a bit. I already have 2" spacers on my coils. I want a few more inches in the front and perhaps an inch or two in the back as well. I have heard nothing but bad things about the SkyJacker 3" lift. I've seen a bunch of members on here with PA body lifts. I've never been a huge fan but I'm thinking now that it may be a nice choice for my application. What are your thoughts on body lifts? What are some possible concerns I should have or issues I may run into?
Old Jan 31, 2007 | 02:13 PM
06STX4x4's Avatar
Well there are a couple options.
1) The grille guard is not going to line up right if you get a body lift without making brackets that raise it up 3". Having the winch on it could make that difficult.
2) Rancho Lift - 4", very well spoken of on here
3) Skyjacker Lift - 4 or 4.5", very good reviews
Other than not being able to have a grille guard line up right without thr brackets, i love my body lift.
Old Jan 31, 2007 | 02:14 PM
JMC's Avatar
JMC
25 Year Member
I have a PA 3 inch Body lift on my 00. No problems so far.
JMC
Old Jan 31, 2007 | 02:30 PM
Bryndon's Avatar
The only issue I've had with the 3" SkyJacker was front shocks that blew out. They replaced them immediately, no questions asked. Other than that, the kit has done everything I expected it to do and more. I do see bad comments about the SkyJacker kits, but I haven't seen many by guys that are running the kit (one if my memory serves me).
I personally don't like body lifts - I've used several over the years. Other than the obvious bumper/grill guard alignment issues, they tend to create a higher center of gravity with no real advantages. The replacement springs are a higher rate than stock, so the extra weight has little effect - I run a 9000# MileMarker in a receiver mount and notice little if any change when it's installed.
Old Jan 31, 2007 | 03:06 PM
jeffmc's Avatar
Options 2 and 3 cost more than I want to spend. Does anyone other than SkyJacker make a 3" lift?
