will 37s fit?
will 37s fit?
If i run a fabtech 6in with a 2.5in spacer in front will it clear a set of 37x12.50 xtreme procomp mts or will it scrub. i will be mounting them on a set of 17x9 procomp 6089s. the truck is a 4x4. any help would be greatly appreciated
yeah its a 2005 f150 4x4 Supercab with the 5.5ft bed. now with me having a shorter bed than most will mine be higher in the rear since i have a smaller fuel tank and bed. it makes since to me since it would be lighter than the 6.5 or the 8fter
well generaly On suspension lifts they make the font suspension alittle taller cause of the weight of the motor So what they do is set it up to were its level. Nos some lifts will no do that theyll give it that baha look were it sits an inch higher in the front which look really good with wheels and tires But if i were you going with 37s Go with the 8" lift.
