Sponsored by: CARiD
leveling/tire questions!!
Old Jan 26, 2007 | 11:48 PM
PunsBoss331's Avatar
ok the 2.5 AS is here! what should i put in the back for a perfectly leveled stance no more than 1" higher in the back if i have to! 3"block mabey? not a fan of aals
Next question how goofy will it look w stock rims and stock tires (they r aggressive maxxis mudders tho) Shoul i mabey run a spacer adapter? the wheels sit in pretty far i want it to have the wide offroad look there stock navigator 18s i dont even think i could run a wider tire without rubbing on the ball joint!! What do u guys think?
i did this on my ranger had narrow 18s with the same 275 65 18s and 6" lift looked stupid as hell then i bought some 2" spacers and it looked like i had nice wide meats in there!!! good idea or no?
If i did go with a new tires whats the widest i can fit on there? im pretty crazy and dont get nervous easy!!! So let me know!
Old Jan 27, 2007 | 07:03 AM
Any help?
Old Jan 27, 2007 | 09:19 AM
wandell's Avatar
I'd install the leveling kit and then decide how much you want to lift the rear. As for the wheel spacers, I wouldn't do that. I'd start saving for a set of wider tires and wheels. You didn't say if you have a 4x4 or 4x2. If you have a 4x4, keep in mind you can fit a 35x12.50 using OEM wheels or a 33 using aftermarket wheels.
Old Jan 27, 2007 | 04:55 PM
its an FX4. was that a typo it dont make sense i can fit 35-12.5s on oem wheels but cant fit 33s on oem wheels?
Old Jan 27, 2007 | 10:01 PM
wandell's Avatar
I meant with a 4x4 and a leveling kit you can fit a 35x12.50, or anything smaller, using the OEM wheels. If you use a wider aftermarket wheel you will be limited to 33 inch tires.
Old Jan 28, 2007 | 12:07 AM
I get what your saying now i think. so a 12.5 will be ok on the stock navigator wheels? i believe there .5" bigger than FX4 wheels dont know backspacing
Old Jan 28, 2007 | 09:11 AM
wandell's Avatar
If they are the same width, or .5 inches wider than the F-150 wheels you should be fine.
