Sponsored by: CARiD
Lift/Leveling question
Old Jan 21, 2007 | 10:35 PM
Shuler's Avatar
I have a 2005 F-250 that rubs the plastic splash guards with the factory tires, and I have been contemplating a leveling kit to remedy this issue. I measured the difference between the front and rear wheel well heights at 1 to 1.25 inches, so any levelling kit would put it nose high. I was wondering if this is not an accurate measure of level and what I could do to raise the rear by about two inches and use a 2.5 inch leveling kit. I have thought about using the blocks from an F-350 as I read they are about two inches taller than the F-250 blocks. I would prefer not to use add a leaves.
Thanks.
Old Jan 22, 2007 | 07:54 AM
wandell's Avatar
That's what I would do. Combine a leveling kit and taller rear lift blocks.
Old Jan 23, 2007 | 11:59 PM
Shuler's Avatar
Thanks Wandell. I suppose I can get the blocks from either Ford or a wrecking yard.
Old Jan 24, 2007 | 08:00 AM
wandell's Avatar
Try www.fordpartsonline.com. Also, aftermarket blocks may be less expensive
