Sponsored by: CARiD
I Dreaming of Lifts
Old Jan 6, 2007 | 12:48 PM
Zepplin27's Avatar
Thumbs up I Dreaming of Lifts
Ive been looking online at lifts so much im Dreaming about them!!
Can i use the leveling kit when i put on my 6 inch lift and if i can will that affect the rear end height. Also I dont want to go and spend $$$$ FOR THE RIZE BECAUSE IM BUYING A NEW FX4 NEXT YEAR BUT FOR NOW I WANT A GOOD BUT CHEAPER LIFT THAN THE RIZE.. HOWEVER WHAT IS THE BEST LIFT OTHER THAN THAT FOR THE MONEY AND INSTAL... iM PUTTING IT ON MYSELF AND THE COST AND ANYTHING TRICKS SOME OF YOU SEN MEMBER'S HAVE FOUND OUT ABOUT THE LIFTS
Old Jan 6, 2007 | 12:54 PM
rrch129's Avatar
you can def stack the spacer but u will most likely have to put an aal in the rear if u want the truck level if u want the cali lean dont worry about it.....i have the rancho 4 inch lift and im thinkin about puttin the spacer i used to have on my truck before the lift back on for a little more lift...
Old Jan 6, 2007 | 01:05 PM
djh1121's Avatar
I got my Fabtech for around $1500 and installed it myself.
Old Jan 6, 2007 | 01:32 PM
Zepplin27's Avatar
grrrr
So what all did you need otherthan your lift with that tough setup... Like did you use your LV spacer and did you have to get a add a leaf to level it out in the rear.
Old Jan 6, 2007 | 03:46 PM
djh1121's Avatar
I did not use my spacer on the front. I did order an AAL the same time I ordered my lift, but have not installed in yet.
Old Jan 6, 2007 | 07:32 PM
allrsdup's Avatar
u can get the procomp cheap on eabay but i would not waste money on a lift now if u are getting rid of it in a year ......just my opinion
Old Jan 8, 2007 | 04:12 PM
dixiehunter13's Avatar
Sorry to barge in on your questions, but what size aal would i need to level out the rear if i put on a coil spacer? 38" tires should be able to fit then? or do i have to do some trimming?
Old Jan 18, 2007 | 07:09 PM
Zepplin27's Avatar
What size AAL should i get for the back if i keep my front leveling kit while adding the 6inch
Old Jan 18, 2007 | 09:42 PM
allrsdup's Avatar
2-3" add a leaf I'd say
Old Jan 18, 2007 | 10:22 PM
ThumperMX113's Avatar
I just don't understand why you're wasting your money now if you're planning on getting another truck soon.
Depends on what size leveling kit/spacer you use.
