Lift or Lower?
Lift or Lower?
I just purchased a new F-150 Lariat SuperCrew FX2. I am interested in buying a leveling kit that raises the front end 2.5 inches but I am not buying new rims and tires. So I would like your opinion on the look that this will provide with my stock 18in rims and tires. I haven't run across any pics of just a 2 inch lift in the front with stock rims and tires so it's hard to judge how it will look. Or if that will give me too much wheel well action should I just lower the rear end to give a level appearance? I feel the lift will make it look a little more beefy but don't want to make it look disproportionate to the tires. Could you give your opinions and maybe a picture or two if you know where I can see the difference?
Thanks for your help,
Rick
Rick
Here is my 2" lift from CCM Off-road... I am currently looking for feedback about this brand as it has a built in offset to eliminate contact between upper control arm and spring. Lots of post here about Auto Spring kit but I went with the kit with the offset. Just installed last weekend and had front end re-aligned yesterday.
https://www.f150online.com/galleries....cfm?gnum=8954
Of the two items which would you suggest?
http://cgi.ebay.com/ebaymotors/2004-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/2004-...spagenameZWDVW
Or would you not suggest these at all?
Thanks for the input guys. I'll post the pics afteward I lift.
what about lowering the rear 2"
theres a member on here that used shackles to lower his rear 2"
& personally i think that would look better on a FX2
what color did you get?
You could do either. You just need to decide on the "look" you want, off road (lift the front and use all terrian tires on 17 to 20 inch wheels) or street (lower the rear and mount street tires on 20 to 24 inch wheels).
Originally Posted by GerRod
Definitely!!! Check out my gallery...my truck is lowered 2" in rear...In my opinion, FX2s are sport trucks...FX4s are 4X4s that should be lifted...
D@MN your truck looks good
just an oppinion/suggestion
but what about solid black bumpers
personally, i think it would make your truck look better
anyways, your truck looks great
sean
THanks
Ok, I figured it out. Yeah, your truck looks great with the lowered rear end. I am not sure if it's just the picture but is your rear end now lower than the front end? Regardless it looks great. I added just a pic from my phone of my truck. I added the nerf bars, DVD player, and bed cover. Looking forward to more mods.
Originally Posted by Stealth
Lower the rear. I had a 2" AS spacer and I ended up taking it off and putting on 2" GF drop shackles. I have pics in my gallery.
