Sponsored by: CARiD
Leveling Decision
Old Dec 23, 2006 | 12:04 AM
JohnBoy88's Avatar
Leveling Decision
Okay, after almost a year of fluctuating between body lifts, suspension lifts, leveling kits, leaving the truck alone, etc., I have finally made a final decision. (Keep in mind that my truck is 2WD).
I have decided to go with a 2" Leveling Kit with 285/70R17 Open Country Toyo A/Ts on stock wheels.
What do you guys think? Will this look good? Is the tire size proportional to the space available?
Thanks.
Old Dec 23, 2006 | 08:58 AM
catfishunter72's Avatar
sorry don't have 4x2, but i just did level kit on mine, i put hankook 285/70/17 on it, turned out great, i have coil over shock set up. Very easy t in stall, check out picks hope it helps out. well worth the $100 i spent
(on my stock wheels)
Old Dec 23, 2006 | 09:36 AM
wandell's Avatar
I think that combo will look great!
Old Dec 23, 2006 | 11:34 AM
andrzej77ff's Avatar
I have a 4x2 with a 2 " leveling kit also and am planing on getting the same size tires, maybe even a 295/70R17.
Old Dec 24, 2006 | 11:47 AM
pacificnw's Avatar
My set up is pretty close... but 4x4
Old Dec 25, 2006 | 05:11 PM
JohnBoy88's Avatar
Thanks.
Will I need new upper control arms?
Also does anyone have any pictures of a 2WD with this level/tire combination? Andrzej77ff's is helpful, but I'd like to see one with the tires too.
Thanks.
Old Dec 25, 2006 | 07:53 PM
wandell's Avatar
You shouldn't need new upper control arms unless you go more than 2 inches. You may need camber bolts to get the alignment correct however.
Old Dec 25, 2006 | 08:06 PM
Budha05STX's Avatar
Thanks.
Thanks.
Here you go....05 2wd, 2" level, 285/70/17 Toyo OC A/T's on stock wheels.
As she sits now. 2" level, 1.5" aal, 285's, 17x8 American Racing Crush (B).
Old Dec 25, 2006 | 09:06 PM
JohnBoy88's Avatar
Well thanks man that was helpfully specific. That's exactly what I wanted.
So are you satisfied with the level/tire choice? Is it a noticeable difference from the way your truck looked stock? Should I go with 295/70R17s or would those be too stuffed?
'ppreciate it. Oh, and thanks wandell you're always helpful.
Old Dec 25, 2006 | 09:17 PM
Budha05STX's Avatar
I've been very satisfied with both. Been running the level for approx. 15,000 miles and the Toyo's for approx 13,000 miles. I would've gone with the Nitto 295's myself but at the time there was a 6+ month wait.
Big time difference in stock vs leveled w/ tires. The pic in my sig is leveled w/ stock tires, I don't have any pics of the stock truck.
Good luck on your desicion.
Old Dec 25, 2006 | 09:25 PM
JohnBoy88's Avatar
So the 285s look good under your truck? Why did you originally want 295s?
Sorry about all the questions. I'm just worried that the 285s will look too small, but 295s will be too stuffed. I'll probably end up going with the 285s but I just want to make sure they look proportional.
Old Dec 25, 2006 | 09:34 PM
Budha05STX's Avatar
I originally wanted the 295's because I like the Nitto sidewall design. The tread patterns are nearly identical but the Nitto's sidewall to me, is better looking than the plain Toyo sidewall. So it was just for looks, :o .
The difference between the two sizes is very little; the 295's will be 10 milimeters wider and (I believe) 14 milimeters taller than the 285's. Either one will be proportional and look very nice.
Old Dec 25, 2006 | 09:44 PM
JohnBoy88's Avatar
Wow. That's really weird that you should mention that because I was torn between the nittos and the toyos because of the same reason. I chose the toyos because you could get the raised white letters and I like those. You can't get them on the terra grapplers.
Anyway, thanks a lot. You've been a great help.
Old Dec 25, 2006 | 09:47 PM
Budha05STX's Avatar
No prob.
Old Dec 25, 2006 | 10:00 PM
Do the 2000 f150's take a leveling kit? I thought they had torsion bars.
