Sponsored by: CARiD
f 150 - f250?
Old Dec 12, 2006 | 12:53 PM
keith97xlt's Avatar
f 150 - f250?
a f 150 with a 5.4, f250 5.4. whats the major difference? just a few more leafs in the back and a solid axle up front right? any other major things or advantages? thanx for any input
Old Dec 12, 2006 | 12:57 PM
bud8817's Avatar
you forgot horrible MPG!!!!!!!!!!!!! if you get an f250 you want a diesle.
Old Dec 12, 2006 | 01:00 PM
kingfish51's Avatar
Things like heavier brakes, frame, transmission, transfer case (if 4x4), and bigger rear (10.25). Not to mention styling.
Old Dec 12, 2006 | 03:07 PM
keith97xlt's Avatar
mileage makes sense. it has to pull around that heavier frame etc...im just debating if i should buy a newer 150 or a 250.
Old Dec 12, 2006 | 04:33 PM
kingfish51's Avatar
Depends on what you want to use it for. A lot of heavy towing and loads, go for the 250. Light towing, go for the 150. If you are doing a lot of towing and expect to keep the truck a while, get the diesel.
Old Dec 12, 2006 | 05:32 PM
keith97xlt's Avatar
well actually more plowing, in up here in mass so that solid fromt axle will probably work out better for me.
Old Dec 12, 2006 | 05:39 PM
kingfish51's Avatar
Definitely an f250 would be hold up a lot better for that. You can get a snow plow prep on the 150, but it requires the heavy payload package.
