Sponsored by: CARiD
coil spacer install
Old Dec 6, 2006 | 06:36 PM
rebelsoul89's Avatar
coil spacer install
are there any shot cuts to put in coil spacers
Old Dec 7, 2006 | 08:57 PM
dodge_slayer01's Avatar
i will tell you what i did. it only took 30mins on one side, but the other took longer b/c it was the first side.
1- after getting wheel and tire off. jack up the truck and put a jackstand under it.
2 - undo the brake calipers and tie them up with a wire.
3 - put the jack under the lower control arm and jack it up to put tension on the coil spring.
4 - undo the tie rods, sway bar, and upper control arms off of the spindle.
5 - lower the jack easily and carefully until all tension is off of the coil spring.
6 - put in the spacer and repeat all steps in reverse order.
alos you might have to take out the shock, you might not. i did it anyway b/c i was replacing them.
hope this helps you. guys if i left anything out please put it in.
Old Dec 7, 2006 | 10:22 PM
thanks ill try your way first
