Sponsored by: CARiD
lift and tires
Old Dec 6, 2006 | 04:25 PM
marine07's Avatar
lift and tires
new to site.... just got my lift and tires in for 1997 ext cab
7 1/2" fabtech
3" body
395/70/16 baja mtz = 37.5/15.5/16
16x10 pro comp 1089
installation is going on the 13th and will be done by 15th. anyone else w/ this setup post pics, i will post after mine is completed for future lifters....b/c i didnt have much luck before ordering. hopefully i wont be disappointed
Old Dec 6, 2006 | 04:26 PM
wandell's Avatar
Sounds nice! Welcome to the site!
Old Dec 16, 2006 | 05:40 PM
marine07's Avatar
done...here it is..... ok i dont know how to insert attachment here....lil help please, also i have come across 1 problem...the spindle hits the tire just a ... should i grind the spindle down or spacers??? also my front tires look like a penguin walking ....i have negative toe and negative camber...so when i take it to get it alignment done i think it will take the pressure/stress of it enough so it wont scrub...because when i lift the truck of the ground it doesnt rub, the tire spins freely
Old Dec 16, 2006 | 09:48 PM
marine07's Avatar
i think i fig how to post pics
https://www.f150online.com/galleries...allery8845.jpg .....well it didnt work the way i wanted it to...
Old Dec 16, 2006 | 10:22 PM
wandell's Avatar
Sweet!!
Old Dec 16, 2006 | 10:25 PM
marine07's Avatar
thanks for posting it for me
Old Dec 16, 2006 | 11:30 PM
Firemed362's Avatar
I was just curious if you truck is an 4x2, i noticed you went with the 7.5" lift, i figured it is but just checking. If it is an 4x2 do you know how much higher the 4x4 sit stock? and was there any trimming needed or rubbing?
Old Dec 17, 2006 | 12:35 PM
_cashel's Avatar
could you post more (bigger) pictures? I'm looking at eventually doing exactly what you just did to your truck, and I think it looks great
Old Dec 17, 2006 | 04:39 PM
wandell's Avatar
97-03 4x4's are approximately 3 inches taller than the 4x2's.
Old Dec 17, 2006 | 04:58 PM
Firemed362's Avatar
Would you know how much higher a 98 sits than a 97. and the 7.5" lift is for the 2wd right?
Old Dec 17, 2006 | 05:08 PM
wandell's Avatar
Ride height on all 97-03's is the same. THe only varible is different tire sizes on different trucks. THe 7.5 inch Fabtech lift is only for 4x2's.
Old Dec 17, 2006 | 05:28 PM
Firemed362's Avatar
Ok wandell thanks for everything. sorry im asking so many questions about so many things i just want to make sure the stuff im going with is going to work. i dont want to get to big of tires or rims and not work with the lift i want.
Old Dec 17, 2006 | 07:18 PM
allrsdup's Avatar
looks great
Old Dec 18, 2006 | 12:02 AM
GLCOOPER's Avatar
Old Dec 26, 2006 | 03:56 PM
marine07's Avatar
i need to trim/cut the fender out....bushwacker doesnt have a cut out for 1997 f150....any ideas? or anyone know of another company?
