cst.....or fabtech w/coilovers????
what would you rather have: fabtech with the coilover and 2.5 spacer or cst.... remember the cst uses stock front coilovers!!! but comes with new upper control arms....... i dono i cant decide!!!!!!! help
its not a good idea to do the fabtech with the spacer and the coil overs unless u keep the coil overs adjusted as low as they go. if u raise them all the way ull be paying 150$ within a month for a new set of ball joints and maybe cv joints. ppl already complain about pre mature wear with just spacers
if u already have the spacer, either sell it or dont use it. it sounds like youre wanting to do some decent off roading if ure that enthused about coil overs. id say go with the fabtech and get the sway aways for 500$ shipped to u. adj. hieght 0-3" and i think the travel is like 11 " !!!, this gives u 9" of height!! sweet! and still cheaper than cst
Guys I'm new to lifts and leveling kits and I've been reading almost all the post here. I am a little confused though and noticed this thread about the leveling kits and lifts together. Why do you need to run both? I thought the lift alone would make the truck sit level. Like I said still learning.
Originally Posted by ThumperMX113
CST, why not Rize though? Just curious.
one more question for ya
.... sence the fabtech brings all the angles back to stock wouldnt putting a leveling kit on top of that be just like putting a leveling kit on a stock truck????? that makes some sence in my brain how bout you???
