Sponsored by: CARiD
steering stabilizer??
Old Nov 27, 2006 | 10:23 PM
BLACKBEAST02's Avatar
have an rcd 5 inch lift on 35's. what steering stabilizer should i get??
Old Nov 27, 2006 | 10:41 PM
Trooks2001's Avatar
The only company that makes them is Fabtech. They have a dual set-up. It works w the procomp and rancho, not sure about the RCD.
*Edit* Thats for 04 and up trucks.
Old Nov 28, 2006 | 12:44 AM
sorry i should have said this in the orginal one. its an 2002
Old Nov 28, 2006 | 08:32 AM
Trooks2001's Avatar
I had a single stabilizer from fabtech on my old '03 not sure if it works with other lifts and I think rancho makes a single stabilizer application also.
Old Nov 28, 2006 | 04:19 PM
wandell's Avatar
Pro Comp also makes a stabalizer.
Old Nov 28, 2006 | 05:13 PM
SKRWZ's Avatar
So does skyjacker and superlift
Old Nov 28, 2006 | 10:09 PM
which ones will work with rcd? and whats the best quality one?
Old Nov 28, 2006 | 10:11 PM
Trooks2001's Avatar
I'm sure they will all be "basically the same" prolly have to contact the companies to see if it will work.
Old Nov 28, 2006 | 10:35 PM
mcpfx4's Avatar
When you add a steering stabilizer do you have to get a front end alignment? If anybod could help me out i would appreciate it.
Old Nov 28, 2006 | 10:37 PM
Trooks2001's Avatar
Nope
Old Nov 28, 2006 | 10:43 PM
mcpfx4's Avatar
Trooks,
Thanks for the info. I just got my 6" Fabtech installed today and wheels and tires went on. The shop did a computer allignment but there is a reputable allignment shop and the guy does it by hand. Best all around. I have an appointment for the morning, the only problem i thought i would have is that my Fabtech dual stabilizer was on back order and it wont be here till Friday. Thanks for putting my mind at ease.
Old Nov 28, 2006 | 10:50 PM
Trooks2001's Avatar
Trooks,
No problem man.
Old Nov 29, 2006 | 02:28 AM
bigtruck311's Avatar
i have the fabtech single steering stabilizer no alighnment is needed, it installs in about 15 min, 3 bolts and 2 c clamps, got mine for $38 a few years ago from 4 wheel parts. it works pretty good but i need a duel with my 38" tires.
Old Nov 29, 2006 | 08:14 AM
ohiodave150's Avatar
do any of the steering stabilizers work on a stock new truck with only the autospring and 35"s? or do they all hook up to pieces of lift components..
Old Nov 29, 2006 | 08:24 AM
it works with all stock components
