Sponsored by: CARiD
ProComp and Autosprings
Old Nov 22, 2006 | 11:36 PM
Truspeeder205's Avatar
I finnally got my Pro Comp basic 6" lift in and i was wondering if i could install the Autosprings 2.5 kit in it just like infantryscum on here... or would i have to run a coil over to do tht...
Old Nov 23, 2006 | 04:00 AM
bud8817's Avatar
not you can do it just make sure to re aline your tires after... install is very very easy!!
Old Nov 23, 2006 | 05:08 AM
hey ur from ventura that like 20 min from where i live... so its possible to do the autosprings 2.5 kit on top of my procomp 6in basic kit...
Old Nov 23, 2006 | 09:05 AM
wandell's Avatar
A few people have bolted the Autospring and other spacers on top of coilovers with their lift kits. However the basic Pro Comp kit comes with a 6 inch spacer to use with your OEM coilovers. I would not use two spacers together.
Old Nov 23, 2006 | 11:54 AM
allrsdup's Avatar
i agree......
Old Nov 29, 2006 | 04:02 AM
Hey guys im goin to order this for my ProComp lift... after tht could i possible clear the 37's i want.... by the way i would have bought the RIZE but i wanted to run these coilovers....
http://www.performanceproducts.com/p...&vehicle=30702
Old Nov 29, 2006 | 07:28 PM
allrsdup's Avatar
if they are adjustable and u can crank them up to give u 8" to clear 37's
but y would u not just order the procompstage 2 kit with procomp coilovers ?
Old Nov 29, 2006 | 07:35 PM
bud8817's Avatar
agreed...... thoughs sway away coilovers are better then the procomps though and if you tighten you coil to get more lift your ride will turn to sh*t!! if you put the spacer on top of that i think you would be fine.
Old Nov 29, 2006 | 11:15 PM
FordTruckX2's Avatar
Post some pics when you do - I'd be interested in how it turns out.
Old Nov 30, 2006 | 05:32 PM
That is exactly what i was goin to do... the only reason i didnt go with the pro comp stage 2 was because i really like Sway Away coil overs and they have the ressovour... and tht they are the closest thing to the KING with out spending the mad $$ plus the sway away is extended an extra 6" made for the lifts.....
