Sponsored by: CARiD
Leveling Kit and 4" Blocks in rear
Old Nov 1, 2006 | 12:04 PM
Racing2Fast's Avatar
I have a friend who found some lift blocks he is going to give me. I have an 04 New style Screw.. 2wd... I was thinking about using the blocks in the rear (4" blocks) and putting a leveling kit up front... the back end should sit 2"higher than the front.. similar to factory set up.. just a little higher all the way around?
Just curious to know if shims would be needed if I use the blocks? I'd like to lift it, but I dont want to go through a lot of trouble.. just looking for some tips or advice... pro's and cons.... thanks!
Old Nov 1, 2006 | 12:35 PM
Duffman0286's Avatar
blocks are fine but ur gonna be adding about a 1 1/2 more rake in the front i dont think anyone gonna be able to tell unless u tell them
Old Nov 2, 2006 | 12:04 AM
Any idea if shims would be needed inorder to keep the drive line and everytyhing in check.... thanks!
Old Nov 2, 2006 | 07:34 AM
all you need is the blocks not that extreme of a change
Old Nov 4, 2006 | 01:06 PM
scott1981's Avatar
Are the blocks angled? That would help reduce vibration and stress from the u joints
Old Nov 4, 2006 | 02:56 PM
no they are flat but the angle does not increase that much dont worry believe your drive shafts joints shouldnt let up down its the fronts on a 4x4 people have trouble with never the rear unless u bust it on a rock or something your ok
Old Nov 27, 2006 | 07:30 PM
F150_B.F.D.M.'s Avatar
what do u mena by blocks in the back.. like.. body lift blocks.. or what..explain plz.. im intrested..
Old Nov 27, 2006 | 09:44 PM
BlueOval Breath's Avatar
Not body lift, They are talking about the blocks mounted under your rear leaf spring bundle on top of rear axle. BoB
Old Nov 27, 2006 | 11:02 PM
o i c.. thanks
i gues there are alot of ways around payin 2k for a suspension lfit!? lol
