new lift kit
the E4OD transmission was an electronically controlled transmission that was usually mated the the 5.8 lt motor in the older f150. I believe that the e40d replaced the aod which was not an electronically controlled transmission. the e4od was much stronger then the aod and I believe came in the 92-96 f150's The e40d has a button on the gear selector to turn off over drive where the aod overdrive had to eb turned off by the gear shifter
