Sponsored by: CARiD
Blocks and Add-a-leaf???
Old Oct 12, 2006 | 12:44 PM
spinnintires's Avatar
I have a '06 2wd xlt and added a 2.5" AS kit to the front. I am going to be adding 35" tires with a 6" fabtech kit in the next month or so, but will be needing around 2-3" in the rear to make me level again and was wondering if i should do a 2" add-a-leaf or should get the factory 4x4 blocks and add those. My only qualm with the blocks is i would be adding a 4" block with the fabtech kit so i would be stacking blocks...how safe (smart) is this to do, any one have any bad experiences with this?? If it seems ok and doesnt change ride i will do this because its about 100$ cheaper, but if the leafs are the way to go, i have no problem spending the extra money to do it right. All opinions are helpful.
Also my truck is sitting dead level now, so since i am adding 6 in front and want a level or slight rake look i will need to be adding 2-3 inches, but are the blocks and add-a-leafs true to the height you install or no???
Old Oct 12, 2006 | 12:57 PM
labman1014's Avatar
i just dont see how 2 blocks on top of each other can be safe, but that is IMO. i would go with the add a leaf since you are dead level now and when you tow your boat, it might sag a lil in the rear. the add a leaf will shore up the factory springs to not sag as much. but like i said that is IMO!!
Old Oct 12, 2006 | 03:17 PM
thank you, i like how we answer each others questions! That is the same thing i was thinking though, doesnt exactly sound safe, but i have heard 2 is ok, some ppl have done 3, that just sounds ridiculous, so im trying to hear ppl out. Thank you for your thought!
Old Oct 13, 2006 | 08:37 AM
Duffman0286's Avatar
dont stack blocks now if you desire you can use the combo add a leaf and the blocks sence your level now now if just just blocks it will sag a little in the back plus add a leaf increase payload and decrease body roll and even some people say improve braking
Old Oct 13, 2006 | 08:51 AM
thank you duffman, i did not know about decreasing body roll, and increasing braking, i did think it was not smart to stack the two, but that was new insight to me. All the more reason to do the leaf over the blocks. I am curious if anyone knows of a brand that sells a leave between 2-3" such as a 2.5 or 3". I am looking to add about 2-3 inches in the rear of the truck, please let me know, thank you!
Old Oct 13, 2006 | 09:35 AM
labman1014's Avatar
spinn- can you tell the height of your front again after the 2.5" AS install. from ground to top of wheel opening. i just want to make sure on what to order, 2 or 2.5 AS. thanks
Old Oct 14, 2006 | 03:39 AM
pro comp and superlift are the most comon but there hundreds of companys that make add a leafs or you can buy higher arch springs and do it that way cost a lot more but the point is you have a lot of options
check out summitracing they will give you a idea on brands and cost
Old Oct 14, 2006 | 11:36 AM
thank you very much for your opinion. I will look into it.
Old Oct 14, 2006 | 12:01 PM
ThumperMX113's Avatar
If your dead level, I'd only do a 1.5" add-a-leaf. 3" and you'll be sitting STINK BUG!
Old Oct 14, 2006 | 12:19 PM
thump, i am adding the leaf along with a 6" fabtech lift, which has a 4" block in the back, i am saying i am level now, but with the lift, my front will be 2" higher, so i was thinking a 2-3" block would then make my back level or a lil high, is this right???
Old Oct 14, 2006 | 12:22 PM
Are you keeping the spacer/leveling kit?
Old Oct 14, 2006 | 12:57 PM
i would like to, but is it a bad idea or can i do it pretty safely???
Old Oct 14, 2006 | 08:09 PM
04sssti's Avatar
Don't stack the blocks due to safety issues, just add the leaf and the truck should look awesome.
Old Oct 15, 2006 | 12:08 AM
but can i have a leveling kit on top of a 6" fabtech lift????
Old Oct 15, 2006 | 02:56 AM
the leveling kit should not hurt your truck in any way your ok to use it
