Skyjacker 3" coil-over
Does anyone have an experience with the Skyjacker [B]Platinum Coil-Over; Suspension Lift Kit; 3 in. Lift[/B]? I was reading some horror stories about the coil spring spacer type lift and this seems like an economical alternative. What would the max tire size I could run with this?
I have an 2005 4x4 Lariet Super crew
The Skyjacker is worse than the cheaper 2.5 inch leveling kits. The Skyjacker lift just goes 1/2 inch higher which causes the same problems, only worse. The Skyjacer lift does nothing to correct CV joint and ball joint angles.
