Sponsored by: CARiD
Lots of frame flex?
Old Oct 6, 2006 | 08:46 PM
mike93f150's Avatar
Question Lots of frame flex?
Hi guys . Your forum is great, I have learned alot about my truck from reading your posts. I have a 93 F150 xlt that I just bought and have noticed that the bumper raises alot when the wheels are turned from left to right. When I went under and looked I noticed that the frame flexes alot when the wheels are turned, also the bumper is sagging on the driver side and the sway bar is missing on the truck. Has driving without a sway bar screwed up the frame or is this flex normal?
Old Oct 7, 2006 | 01:45 PM
scott1981's Avatar
Driving without the swaybar would not harm anything. The frames do have some flex but you might want to inspect the frame rail for any cracks or rust spots just to be safe. After that alaign the bumper and you should be good. With my Dodge when I would go offroad and flex the suspenion you could see the cab and bed of the truck going opposite directions 4" or so. It wasnt pretty but always returned to normal once on flat ground
Old Oct 7, 2006 | 05:56 PM
mike93f150's Avatar
thanks! I feel alot better knowing that. Im going to get a bar for it soon.
Old Oct 9, 2006 | 12:34 PM
Duffman0286's Avatar
keep in mind if want less flex crossmember and bracing can bought/ made and ethier bolted or welded in place to limit this
