Sponsored by: CARiD
4wd look on a 2wd
Old Oct 5, 2006 | 10:16 PM
labman1014's Avatar
4wd look on a 2wd
what is the easiest way to get the 4wd look on a 06 screw 2wd?
Old Oct 5, 2006 | 10:40 PM
Fordwitflows's Avatar
3" body lift-since the 4wd sits 3" higher then 2wd
Old Oct 5, 2006 | 10:42 PM
Trooks2001's Avatar
With a bodylift you will still sit lower in the front b/c it raises the entire truck 3". To get the "4x4 look" you need to install a 2.5" level kit in the front.
Old Oct 6, 2006 | 07:57 AM
wandell's Avatar
Also, the 4x4's have a 2 inch lift block in the rear.
Old Oct 6, 2006 | 08:30 AM
labman1014's Avatar
so i need a 2.5" leveling kit in the front and 2" block in the rear?
Old Oct 6, 2006 | 03:59 PM
wandell's Avatar
That would put your rear height the same as a stock 4x4 and your front about 1/2 inch taller than a 4x4.
