New member just installed bilsteins 5100
Originally Posted by Virtygo
The way the bilsteins are designed, there are two notches on the shock body. One at stock height and one two inches highter. The purpose of these twon notches is to hold a metal flange (using a c-clip). That flange in-turns is what hold the spring seat for the stock coil. That's how they accomplish the preload on the coil (much like the Daystar I'm assuming). If you want to use the bilstines and an AS kit, you could move that c-clip to the stock height and assemble the coil with the stock preload height settings. But that would defeat the purpose of the shocks, unless you have the AS kit alread. But then you don't get the benefits of the adjusted shock valving the bilsteins were designed for.
Virtygo -
i just got my 5100's delivered but something doesn't seem right. Mine has 3 nothces and they are 1 3/8" apart. yours only had 2 notches?
Ron,
Sorry for the delay, i don't get to read this forum often and the holidaze and stuff kept me away.
Yeah my 5100's had only 2 notches. I have the 'newer' can silver in color. Not sure the discrepency in the notches, i read the earlier versions had 3 settings (belived they were a yellow can).
Sorry don't have a difinitive answer for you.
