Sponsored by: CARiD
What gears?
Old Oct 1, 2006 | 09:00 PM
Fordwitflows's Avatar
What gears?
For you guys (and gals) with 6" susp and 3" BL runnign 37s or 38s-What gears are you running? Will an edge evo do the job of adjusting the speedo?
Old Oct 1, 2006 | 09:02 PM
Trooks2001's Avatar
Edge will correct speedo. I wanna get 4.56 with my 36's.
Old Oct 2, 2006 | 04:28 AM
bigplayer6907's Avatar
im looking in to the edge or superchips and planning on gettin 4.88s
Old Oct 2, 2006 | 06:47 AM
Bigplayer-I plan on doing your same setup(6"susp+3"BL). I already have body lift. How do you like the setup. What else have you done to the truck to make it "work". i.e. stronger brakes, gears, steering. Or did you just throw the lifts and bigger tires on and drive in stock.
Old Oct 2, 2006 | 07:58 PM
Bigplayer^^^^^^^^^^^^^^^???
Old Oct 2, 2006 | 11:22 PM
as of right now all i have done is upgraded my rotors with slotted and crossed drilled. in a month or so i will be changing out my gears to 4.88s. to fit 38s with a 6 and 3 you need to a do a little trimming on the lower valence, the fender flare, and the fender wall. otherwise everything works
Old Oct 9, 2006 | 09:36 PM
redneck101's Avatar
Im running the same setup as bigplayer, with 4.56 gears. The truck pulls good and will still peg out the speedo.worked good for me
Old Oct 10, 2006 | 01:31 AM
i went and checked on the egde evo the other day. it doesnt correct the speedomoter it just shows the correct speed on the programer. it will also only program up 35s with 4.56s i think. im yet to find a programer that will tune 38s with 4.88s
Old Oct 10, 2006 | 10:57 AM
redneck101's Avatar
I've got a hypertech.Had to do a little playing but I finally got it.Set the gear ratio at 4.10 even though I have 4.56,and the tire size at 34 even though i've got 38's.turned out to be 2mph fast.
Old Oct 10, 2006 | 01:10 PM
Trooks2001's Avatar
Thats weird. My Edge (04-07) models corrects speedo on the dash and goes up to or past a 38" tire. Pretty sure it will go to a 4.88 gear to but havent looked so dont hold me to it. Wonder why the 97-03 Edge's dont do the same?
Old Oct 11, 2006 | 08:29 AM
Duffman0286's Avatar
go 4.88's if your evo will not adjust it there is the superlift or jet speedo calurbation units $150-200
