Sponsored by: CARiD
air ride ??
Old Sep 24, 2006 | 08:01 PM
phattbaztard03's Avatar
Question air ride ??
I would like to use a bag-behind-axle setup and I was wandering if I did not have CUT into the bed? I was told that i shouldnt but I just wanted to make sure. also if I use this setup would I lay all the way out?
thanks for the help in advance.
Old Sep 25, 2006 | 04:28 PM
newstylecustoms's Avatar
Originally Posted by phattbaztard03
I would like to use a bag-behind-axle setup and I was wandering if I did not have into the bed? I was told that i shouldnt but I just wanted to make sure. also if I use this setup would I lay all the way out?
I am assuming that you mean "cut" into the bed. You won't be able to go very low without notching the frame and that will require cutting into the bed as well as cutting the fender wells out for tire clearance. So it depends on how low you want to go, but laying frame without a monster notch is not possible.
Old Sep 25, 2006 | 04:41 PM
I was thinking the same thing with the monster notch. I was originally going to monster notch and bridge, but i was told by a friend that i would not have to with bag-behind-axle.
thanks
