Fox Coilovers
Originally Posted by dirtysnow
true, but why in the world would you spend even more money for a longer king c/o thats actually made for off road racing for use on a lift kit? and the longer ones dont bolt up to the stock buckets. you would have to fab a new shock hoop.
Originally Posted by ThumperMX113
But, King is supposed to be coming out with a shock for our exact set-up. I'll probally just have to wait it out and hope they do make it.
Yes, you could. But if you're spending all of that money, why in the world would you want to use a King coilover with a spacer?
bottom line- the lift is going to break before you use the kings to thier full potential, which means its a waste of money. go with bilstien or rancho
rancho rx9000x coilover
http://www.autoanything.com/suspensi...A2839A0A0.aspx
bilstein 9100 coilover
http://www.bilstein.com/fourwheeler_may.pdf
If you call some of shock companys they may offer longer shocks.I did find a place CA called Kaos PH#951-737-9682 that offer a tube style upper A-arm with a huge ball-joint.It can only be used with 4-1/2" back spaced wheels.The mount on a King Shock set-up can be used with any coil-over from the looks of it.You can make anything work,if you have the money to put in the truck.
