how many inches for leveling kit
i just ordered my 2.5"autospring leveling kit and now been reading how it is gunna make the front taller than the rear. Is this true? i definitely dont want the rear draggin. anyone got the inch specs on this setup.... 2004 supercrew FX4. i plan also puttin a 6 inch lift on too... to sum it up, i just never want the front to be higher than the rear. Level is fine. thanks fellas
it will probably be level with what you ordered or possible with the front a tad lower than the rear until you put a load in the truck, then the tail may be low. You may want to review some of the posts regarding front end problems due to leveling kits before you install so that you make an informed decision.
yeah ur truck has a really good stance to it.... That makes me feel alot better about it. i just read so much stuff saying go with 2.5" so i did and i started seeing other stuff saying the nose will be a lil higher. thanks bro
