Sponsored by: CARiD
outer tierod question?
Old Sep 6, 2006 | 08:24 PM
f-150dearkiller's Avatar
how the heck do you disconect this thing from the adjust tube??? it wont screw out???help
Old Sep 7, 2006 | 07:55 AM
wandell's Avatar
It should screw out.
Old Sep 7, 2006 | 05:10 PM
i know but it just wont move i even tried a breaker bar. should i use the torch and heat it up???
Old Sep 7, 2006 | 05:50 PM
jlcotney's Avatar
Replace the inner tie rod and the adjusting sleeve too. Everything will go back together like new. Just make sure to screw everything back together so that the overall length is the same as the old assembly. Chances are if the outer is bad the inner isn't far behind. I replace all the tie rod ends and both sleeves at 75000 because they were shot. Much easier than trying to unscrew from the sleeve and only costs about 20 bucks more. Just my two cents.
Old Sep 7, 2006 | 05:57 PM
inner are in good shape im only replacing the outer because i busted and stripped the bolt lug on the end of the outer rod end and cant get the castle nut to screw back on
Old Sep 9, 2006 | 11:21 AM
FrankLee's Avatar
Left-hand threads???
