Sponsored by: CARiD
Need advice on lowering kit
Old Aug 6, 2006 | 03:15 PM
BlackandProud's Avatar
I have a 97 xlt off orad 4x4 and wanted to drop it, because it is very impractical for where i live. I want a even gap around the tirewells. The truck unloaded has 9 inches from the bottom of the wheelwell to the top of the tire. THe front has 5 inches. I just installed bilstein HD shocks all the way around, but will part with hem if neccisary. I was wondering, short of airbags, what is the best drop setup for my truck. i have oem fx4 rims, which i will be running wider tires on, for an aggressive look. any feedback or pics would be greatly appreciated.
Thanks, Rob
Old Aug 6, 2006 | 03:51 PM
Bartak1's Avatar
You can pull out the factory blocks in the back, and that will lower you 2 inches. From there, you can get new shackles (most lower around 2 inches), then you could also get new hangers, which can put you down another 2 inches. So right there you can be 6 inches lower in the back.
As for the front, you might be able to turn down your T-bars some, however I dont think I would turn them down too much. There are kits out there made to lower front with new T-bars, and other stuff (not sure what they come with exactley, maybe different lower control arms??). I believe Belltech makes a kit, might want to try searching for that.
