Sponsored by: CARiD
ball joint installation
Old Jul 31, 2006 | 05:43 PM
1jskyking's Avatar
1999 F150 4WD,
I need to replace the upper and lower ball joints ( 95K miles) and I am trying to figure out if I can replace the upper ball joints without having to replace the entire A-frame/control arm.
the associated threads have pointed me in both directions so I am a little confused since I haven't ever installed ball joints.
any tips,techniques, suggestions are otherwise are gladly appreciated.
thanks in advance.
jt
Old Jul 31, 2006 | 06:20 PM
powerage's Avatar
If the upper's have never been changed before you will need to replace the entire control arm. The lowers are replaceable.
Tips -- Get a pickle fork for removal. Lowers will need to be pressed out and then back in. Upper's will be cake if you replace the control arm.
Old Jul 31, 2006 | 07:03 PM
lees99f150's Avatar
if you have the stock upper ball joints you will need to replace the whole A-arm.
you should also get the 4 cam bolts and washers when you replace them so its easier to do the alignment.
do a quick search here and you will see a bunch of tips and tools to use.
