shock question????please help
i have a 2000 f-150 2wd and am going to put on a leveling kit . the truck is going on 100k miles should i replace the shocks??? reason i ask is i cant get the bolt off to drop the shock to install the levelong kit . can i just cut the shock bolt and replace the shock ??? thanks guys
It does sound as if you need to cut the bolt off and replace it. As said before if periodic maintenace is performed these things don't get to the point of "Needing to be cutoff" anyway I hope your project goes well and spend as much as possible(within reason) and do it right the first time.
guys i cant seem to find any replacement shocks for the front? its a 2000 f-150 2wd. dont want to spend to much but need to know where to get them . for once i couldnt find what i was looking for on e-bay.
http://www.shox.com/
Make sure you get a new bolt fromt he dealer to replace the one you just cut off!
no no its not a factory bolt, it is the top of the shock that goes threw the spring carige it comes on the shock
Thanks for the link Jordan. I've been thinking about doing this.
I once broke of the factory front stud that is pressed into the front part of the suspension on a Ranger. Just cut it out and put a bolt of the same size through the hole. Tacked the backside just for extra measure. Tightened it up and it worked fine.
They had Bilstein, Koni, and Tokico sets of 4 for $260-210.........
Originally Posted by F-150dearkiller
that site mike was to expensive i dont want to pay 150 dollars for 2 shocks im more leanning toward 50 total for 2 front shocks
Bilstein or Monroe are quality shocks.
I have Rancho RSX's and they are good but a little more expensive. About $50 each.
Bilsteins are a bit expensive, but they have a lifetime warranty.
And are pretty darned good shocks IMHO.
I've never seen them lower than about $65 each. That's about what I paid.
