Sponsored by: CARiD
wich 6" lift??
Old Jul 21, 2006 | 01:06 AM
Synergy16's Avatar
Exclamation wich 6" lift??
I have a 2004 2wd XLT 4.6 and i want to lift if 6" i already have a 2.5 daystar level kit with 33" bfg A/T on stock rims i was thinking about 20x10 Moto Metal 951's on 36x13.50x20 Mickey T Claws sound good to anyone and what kit should i go with?
Old Jul 21, 2006 | 01:09 AM
-TXF150-'s Avatar
To tell you the truth, in order to run those tires on a 2wd, ur gonna need to run the fabtech 6" plus your daystar spacer... Or You could go with the CST 7" 2wd lift...
Old Jul 21, 2006 | 01:25 AM
Synergy16's Avatar
I was panning on runnin both kits for a 8.5 and im not sure whether to go with the fabtech or procomp 6" i would go with rize but its a bit too much.
Old Jul 21, 2006 | 01:53 AM
patshea098's Avatar
go fabtech unless your gettin the coilover kit go with pro comp cause you get the adjustable MX-6 shocks for the rear.
i say the CST 7"
and the rize kit is for 4WD only anyway....so yeah.
Old Jul 21, 2006 | 10:32 AM
ThumperMX113's Avatar
What kind of budget are you working with for the lift?
Old Jul 21, 2006 | 11:47 AM
se12t's Avatar
procomp worked out good for me and I tested it in a quarry, did good, good flex, and smooth ride on the road back home.
Old Jul 21, 2006 | 12:08 PM
-TXF150-'s Avatar
Running a 6" lift plus a 2.5" spacer will make your 2wd truck the same height as a 4x4 with only a 6" lift...
Old Jul 23, 2006 | 03:16 PM
Synergy16's Avatar
Well iv'e decided to go with the procomp 6" with the daystar kit as well on procomp x-terrains 35 13.50 r17 Thanks for the help!
Old Dec 23, 2006 | 07:21 AM
PATRICKS FX4's Avatar
Exclamation I did not know this
That is good to know.... I am planning on lifting my '04 FX4 w/ a Fabtech 6" lift, black moto metal 951's and 35" procomp xterrains. I have been curious though because i have read a lot from these reviews and people have got the 2.5" leveling kits and the fabtech/ procomp lifts. So just to confirm, since mine is an FX4 (4x4) there would be no reason to install the 2.5" spacers?
Old Dec 23, 2006 | 09:23 AM
wandell's Avatar
Right. You will be fine running 35's on a 4x4 with just the 6 inch lift.
Old Dec 23, 2006 | 04:10 PM
Red face
so if I get a fabtech lift, is my truck going to be "raked" in the front. In other words is there going to still be a 2.5" drop or so on the front versus the rear like stock trucks? I just want to make sure that it is leveled off.
https://www.f150online.com/galleries....cfm?gnum=8844
Old Dec 23, 2006 | 04:56 PM
04 F-150's Avatar
Back to synergy...I got the Fabtech for my 2wd and it is awesome, in order to clear that size of a tire, these guys are right, you are going to need the 7" lift. Other than that, I have the Mickey T claws and they are awesome and pretty much everyone else on here as the 951's (just joking guys I don't want to start a war) so you shouldnt see any problems with those two. Good luck with your final decision.
Old Dec 23, 2006 | 11:05 PM
wandell's Avatar
Most lift kits are designed to level the truck. In other words most 6 inch kits will lift the front of the truck 6 inches and the rear only 4 inches.
