Fabtech Vs. Procomp
Hey guys
I just wanted to know the difference of both kits. I have a 2001 suprcrew 2wd and wanted to lift it with a spindle kit. I noticed that procomp comes with add a leaf for the rear thats 1 and a half inch and fabtech comes with 2 inch blocks. Would any of these kits make the truck not sit level? Also Fabtech has 3 and a half inch spindles and procomp has 3 inch. I want my truck to sit level with the lift which one should I buy or are they both the same? How about springtech from suspension max is that a good kit? Also does anyone know how tall the truck will sit with one of these kits? (Any photos) Any of your advise would be of great help, any recommendations on what dealer to buy from? Thanks!
I have the 6" procomp with 35" tires, the truck sits approximately 8 to 9" taller. You can put 37" tires but you will be right at the edge. No problem with the procomp and I did put it to the test. The price varies if you with or without the coilovers. Coilover kit is more expensive but it is better.
anyway you can check the gallery for the procomp on mine
https://www.f150online.com/galleries....cfm?gnum=7504
