truck leans?
truck leans?
i have noticed that the whole left side of my truck leans. i wonder if its the coil springs and the leaf springs starting to sag. does anyone else have this problem? i will go out tomorrow and measure.
Originally Posted by ThumperMX113
Do you have a body lift? Did you check the simple stuff, like tires?
Originally Posted by Whapt
checked the shocks out one may be bad or a bad leaf spring
well i finally got around to measuring the truck. from the center of the wheel to the bottom of the fender.
front drivers side 23 1/4
front pass. side 23 1/4
rear drivers side 23 1/8
rear pass side 24
i cannot see why the pass. side rear is that much higher. i had the truck on level ground, uneven terrain wasn't a problem. i guess the other leaf spring and front coils are sagging. i dunno.
rear pass side 24
